| Yes - correct. But But, in addition - If you look at the pic you linked to... A couple inches lower on the heater pipes from the nipples you point to there is one more 'nipple' on each heater pipe. It's tough to tell due to the angle on the pic, but you will probably have to cap those too. You'll see them once you get going. When I did mine a couple years ago I missed them. I ended up soiling a new pair of headers as they got doused with coolant. These lower connections are in your face with the plenum off but knucklebusters with it on.
8.5 to 1 CR NA. For the moment.... |
